I am new to this forum and using TV Paint for the first time. I watched tutorials and looked around on this site, but I still struggle a lot.
I have made an animation per hand that I must put on TV Paint until Friday (I'm a student), and modify it a little using TV Paint.
I have several problems...
When I try importing scans, and I select the first scan in my file, TV Paint imports several scans at once athough I didn't ask for that.
Once imported, some scans are the right size and some show a zoom on my scan... although all scans are jpg, same format.
It would be very helpful if someone could give me advice on how to manage the scans.
Urgent problem importing scans
Re: Urgent problem importing scans
1. If you don't want all images imported, check "single image" in the import panel. (TVP imports all files within a naming scheme, like name001, name002, name003)
2. Un-check "stretch to project size" in import panel.
Good Luck!
Good Luck!
Thank you, I will try that!
