Brush needed!
- David_Fine
Brush needed!
I am looking for a brush to give a natural media texture. In the attached picture, on the left, I used the 4B pencil (adjusted and with opacity reduced) to get the effect you see. On the right, I used a Dry Brush in Photoshop. The one on the right has more grain and a nice graduation from dark to light. Also a random pattern without it going solid black. I can't find that in TVPaint, so I wonder if anyone has any suggestions as to how to achieve that or a brush like that already.
- Leech texture.jpg (81.17 KiB) Viewed 10403 times
David Fine
Snowden Fine Animation Inc.
Vancouver, Canada
Vancouver, Canada
Re: Brush needed!
I made a brush and recorded this video to show you how to make your own custom brushes.
http://www.tvpaint.com/forum_attachment ... -brush.mp4" onclick="window.open(this.href);return false;
- David-Shadow-Brush.tvpx
- (171 KiB) Downloaded 668 times
- David_Fine
Re: Brush needed!
This brush is great! Thank you so much, Elodie. I was aware of how to make brushes, but was not sure how to achieve this one easily, but your video is also very helpful. I find that the opacity and the stepping makes a huge difference too. So many small tweaks that can be made to get it just right.
David Fine
Vancouver, Canada
Vancouver, Canada
- David_Fine
Re: Brush needed!
David Fine
Vancouver, Canada
Vancouver, Canada
Re: Brush needed!
You're welcome ! That's the naughty side of custom brushes : once you start, you can spend several hours in making different ones, just by changing "a tiny little parameter here, and this one too, and... blimey ! That's not what I expected, but it's pretty cool ! "
- David_Fine
Re: Brush needed!
I stamped a sequence of the brush you made me and added few more scattered marks around it to soften the edges further and then grabbed it again. Both are good, depending on the desired effect.
David Fine
Vancouver, Canada
Vancouver, Canada
