I'm not able to open a three months old file because of this warning: TVPaint freezes up and I cannot click "OK". What should I do
![Confused :?](./images/smilies/icon_confused.gif)
Sir, at first I suggest to use "import Phootoshop PSD" & "Export to PNG" function on Adobe Fireworks CS 3 - CS 6 if you have.furushil wrote:Hello,
I'm not able to open a three months old file because of this warning: (images)
TVPaint freezes up and I cannot click "OK". What should I do?
ten_zero wrote:And second I introduce you to use ImageOptim.app or Lemke Software GraphicConverter.app for delete exif infromation and delete aplha channnel from PNG on Apple OS X.
The director sent me a screenshot png file with correction and I imported the file in TVPaintElodie wrote:Do not use sRGB profile when exporting a PNG from Photoshop.
When the director took a screenshot by OS X "Command+shift+ numeric 3-5" shortcut, ImageOptim will very helpful item for both.furushil wrote: The director sent me a screenshot png file with correction and I imported the file in TVPaint.
Me too.furushil wrote:which setting would be recommended here in photoshop? :
I am using Photoshop CS5
Let us see simply, because it is out of TVPaint Animation's function and support.furushil wrote:I just don't understand if sRGB is always bad or is it sometimes better to choose sRGB.
Should I always avoid it?
Is it only relevant if I want to print something?
I looked up on the internet that sRGB is very important but I don't know if it is important for me.
Could you please send us a PNG as an example, so we can run a few tests ?furushil wrote:I would not say that it is solved because TVPaint sort of crashes when the messages pops up and I have to force quit it. I should be able to click on "OK", I think.
