Create a Menubar
Broughtvulture
Create a Menubar
Post by Broughtvulture »
Is it possible to create a Menu Bar and then add your own content into that Menu Bar, using George Scripting? I want to create my own Custom Panel, using George Scripting.
I've got some of the basics down and know how to do simple coding based off this reference: http://wiki.tvpaint.com/index.php?title ... _Reference" onclick="window.open(this.href);return false;
I appreciate any help and if what I am asking is not possible, how did LazyBrush do it?
lazy-brush.com/
Specs:
TVPaint 11.0.3 Pro - 64 bit
Windows 7 64-bit
FX 8350 8 Core - 16 GB RAM
TVPaint Professional 11.0.8 64-bit
BNV
Re: Create a Menubar
I'm not sure if I get what you want. Usually you create a custom panel and fill it with buttons, which can use keystrokes, brushes or george-scripts. The buttons are all of the same size and can't display any informations. Is it that what you want or do you try to achieve something different ?
NathanOtano
Post by NathanOtano »
You can put scripts on george panels but not create panels with scripts. You'll have to create plugins for those kind of things (but i'm not sure how it works)
Lazybrush is not integrated with tvpaint I guess, it's just interacting with your wacom driver on your OS. I was thinking about lazy nezumi sorry
Broughtvulture
I want to be able to edit tool parameters in real-time, like the default panels on TVPaint can.
I heard about George Panels, in context of a word or two; but never got to see them in action or understand how to implement them.
Hopefully the picture will reduce the confusion. I want to make a panel like the Green box, where all changes are made in real-time and you have the ability to change multiple parameters.
Windows 7 64-bit
BNV
Orange and violet are possible, green isn't, as far as I know.
George scripts are plain text lists of instructions that can be assigned to buttons. Clicking a button executes the script.
Custom Panels contain custom buttons which offer one or more of the following options when you right click on a button:
1. execute an individual George command
2. set APen color
3. set BPen color
4. set a tool and its parameters
5. set stored light table settings
6. execute a George script (scriptname.grg)
7. execute an embedded George script
8. execute one or more keystroke actions (one per line)
9. execute an FX .bin file
10.execute a Plugin
11. open/close/toggle a SYSTEM panel
What you are trying to do is create a SYSTEM panel which requires programming in C that makes calls to functions in the TVPaint SDK (Software Development Kit) which compiles to a custom plugin that can be incorporated into TVPaint so that it is loaded at startup. That is how the LazyBrush SYSTEM panel plugin was created.
Wikipedia - Plugin
Bottom line, George scripting won't do what you want to do.
NathanOtano
Sorry for the mistake, I was writing lazybrush but talking about lazynezumi which is a completely different thing :?
Broughtvulture
Svengali wrote:George scripts are plain text lists of instructions that can be assigned to buttons. Clicking a button executes the script.
2. set APen color
3. set BPen color
10.execute a Plugin
Wikipedia - Plugin
The truth hurts, but either way I appreciate everyone's effort to help; Thanks.
Windows 7 64-bit
BNV
