If you want to use the drawing recorder to animate up a drawing how do you to it best?
When you copydrawing an image like inmy case you often not draw so fast as you want the priewe later should be so the get far too many frames. I tried to solve it partly by starting a project with 10 fr/ sec but I am not sure if that was the best way. It´s still way too many frames.
Or can I go into the timeline and somehow delete every second frame easily?
Great thanks!
/ Mattias
drawing recorder Topic is solved
- hellofilms
drawing recorder
Windows 11 - TVpaint Pro 11.7.4 & 12.0.2 .- Wacom cintique 24 Pro
Re: drawing recorder
You can shrink the layer to speed up the drawing (if I understood what you want) :
http://www.tvpaint.com/doc/tvp11/index. ... rink-layer" onclick="window.open(this.href);return false;
- hellofilms
Thanks,
That could be useful. I will test it.
/ Mattias
/ Mattias
