Air brush tool not working ?(Colorize effect)
Posted: 29 Dec 2016, 12:48
by cyrus rebello
It's been an hour but i can't get tvpaint to apply the colorize effect when selected
(In the following picture i've selected black, and wish to color the grey lines into black (And i tried using darken only too but that didn't work, however lighten only works with a lighter color than black. eg: green)
http://imgur.com/a/1YBzY" onclick="window.open(this.href);return false;
In short, lighten only option in the airbrush only works with a lighter color than black, but colorize doesn't work with black when the lines are clearly grey
Edit: Colorize doesn't seem to work with any color
So it can't color low opacity lines?
Any suggestions?
Re: Air brush tool not working ?(Colorize effect)
Posted: 29 Dec 2016, 13:01
Colorize works with grey lines.
It doesn't work with completely black or white lines (on transparent), and it doesn't work with black lines being 50% transparent - maybe that's what you try?
But you can create a layer with 100% white under your strokes and merge it with them, then the former 50% opacity lines will become grey and can be colorized.
Posted: 29 Dec 2016, 13:23
Maybe you should first update your license to TVPaint 10.5.7 :)
Posted: 29 Dec 2016, 13:27
by cyrus rebello
Still no luck, i've redrawn the lines with no opacity, same situation
Posted: 29 Dec 2016, 13:29
by cyrus rebello
Elodie wrote:Maybe you should first update your license to TVPaint 10.5.7 :)
Actually, yeah, since moving to an old pc of mine which has this version of tvpaint felt a lot more closer to home , i haven't updated it yet
I'll update and give it another try
Posted: 29 Dec 2016, 15:59
by Fabrice
I confirm the problem is fixed in the 10.5.7.
you just have to update.
Posted: 02 Jan 2017, 12:33
by cyrus rebello
Fabrice wrote:I confirm the problem is fixed in the 10.5.7.
Yes, sorry for not replying
The problem is actually fixed in 10.5.7 and above
Thanks again guys!
