TVPaint Animation has stopped working
Posted: 30 Jan 2017, 00:41
Hi, I can no longer use my copy of TVPaint - it crashes every time I try to open it.
I am using 10.5.7 32bit standard edition on windows 10. It worked fine last year.
I've seen suggestions that it might be a wacom driver conflict, but the problem persists even after uninstalling the wacom drivers. Any help would be appreciated, I need the software to complete a job.
This is the text of the error:
edit: I downloaded the TVP 11 demo and that works.TVPaint Animation 10 (32bits) has stopped working
A problem caused the program to stop working correctly.
Windows will close the program and notify you if a solution is available.
