Jagged lines in new dematerialized version– no more wintab/subpixel?
Posted: 25 May 2022, 21:09
by BellaLemieux
Hi! I just updated to the dematerialized version of TVPaint, and I've noticed my lines are jagged again. I used to be able to fix this by selecting preferences and checking off the wintab/subpixel option, however it is no longer there. I tried the Boost Line Smoothness option but I hate drawing like this because the line lags behind my pen. Is there any other way to solve this? I'm on macOS Big Sur just for reference. Thank you!
Re: Jagged lines in new dematerialized version– no more wintab/subpixel?
Posted: 25 May 2022, 21:20
BellaLemieux wrote: ↑25 May 2022, 21:09
Did you just switch from Windows to MacOS ? Because there was never an option for checking a Wintab/subpixel option in the Mac version. Wintab is a Windows thing.
Posted: 25 May 2022, 21:27
by BellaLemieux
OH you're right I'm so sorry. I did just switch from a windows to a mac computer, I didn't even think about that. Is there any way to fix this though? It bugs me a lot. :/
Posted: 27 May 2022, 14:34
BellaLemieux wrote: ↑25 May 2022, 21:27
Well I hope someone from TVPaint Support will answer you soon about how you can fix this issue.
In the past when I have read about people having problems with brush lagging and jagged lines one solution mentioned is to set TVPaint to Open in Low Resolution.
Right-click on the TVPaint application in your Applications folder , select Get Info. In the Get Info window put a checkmark in the box next to Open in Low Resolution.
I don't know if this will solve your problem , but it is worth a try until someone from TVPaint Support will answer your question.
- TVPaint Open in Low Resolution mode.jpg (85.6 KiB) Viewed 2742 times
Posted: 27 May 2022, 15:12
by Matthieu
You can indeed try what David recommended above first.
I would need to know which graphics tablet model you are using (is it a screen-based one)?
