Page 1 of 3
TVPaint 11.7.0 operation check
Posted: 23 Sep 2022, 08:58
by Hironori Takagi
I confirmed the added features while translating the TVPaint 11.7.0 release notes.
I am aware of the below issues.
(1) If 11.5.3 is set in Japanese, it will be in English when 11.7.0 is started for the first time. (There seems to be a problem with the selector in Preferences → Basic → Language)
(2) The hotkey "select mode" only displays "next mode" in the Japanese menu.
(3) DPI is not reflected when exporting as PDF.
(4) DPI is not reflected in export using George such as tv_savedisplay, tv_clipsavestructure.
Thank you for your confirmation.
Re: TVPaint 11.7.0 operation check
Posted: 23 Sep 2022, 09:53
by Thierry
Hello Takagi-san,
Thank you for the information.
We will look into this, so this doesn't happen again for later releases.
Thank you, we will update the localisation for the Japanese language as soon as possible.
My apologies. The changelog we sent you was an earlier version and we later noticed that the DPI are not in the PDF export, so I edited the changelog.
Good catch!
I will create an entry in our list, we'll try to add it in TVPaint 11.7.1 (which we plan on releasing before the end of the year).
Posted: 26 Sep 2022, 01:40
by Hironori Takagi
Thierry,
thank you for your reply.
(2) and (4) are important issues, so please be sure to address them in the next minor version upgrade.
Regarding "reading the DPI set when the image is imported", which we requested to Antoine in advance, it is also essential for us.
Posted: 26 Sep 2022, 14:30
by Thierry
Hironori Takagi wrote: 26 Sep 2022, 01:40Regarding "reading the DPI set when the image is imported", which we requested to Antoine in advance, it is also essential for us.
This will be in the next minor update, v11.7.1, which will be released before the end of the year.
Posted: 27 Sep 2022, 07:16
by Hironori Takagi
I found one more problem with the export.
The following update of the release note has caused a problem for the operation so far.
When exporting named images (instances where the name is set by the user instead of the default name), the “All Images” checkbox should correctly export all images (1 frame = 1 image file).
This rule will create wasted frames in TVpaint 11.7.0 when using George "tv_ClipSaveStructure" command (export heads of the instance).
Please let me discuss whether to return to the original rule or add George's command to deal with it.
Posted: 28 Sep 2022, 08:38
by Xavier
Hironori Takagi wrote: 27 Sep 2022, 07:16 I found one more problem with the export.
Indeed, there seem to be a small issue. I reproduced it even using the Export panel.
Just being curious: what do use the named images for ?
Posted: 28 Sep 2022, 08:44
by Xavier
Thierry wrote: 23 Sep 2022, 09:53
Good catch!
That was done on purpose: the DPI management is meant for static pictures, not for an animation sequence. What would be the need ?
Posted: 28 Sep 2022, 08:49
by Xavier
Yet you're right, if the option appears it should have an effect on the exported files...
Posted: 28 Sep 2022, 09:55
by Hironori Takagi
Xavier wrote: 28 Sep 2022, 08:38
In Japanese production, the same image is often used multiple times, so we use instance name = video number (for example, 1 → 2 → 3 → 2 → 1).
The default values "1." "2." "3." "4."… will not solve this problem. I thought about solving it with XSHEET, but I gave up on that method because there are too many layers.
As a reference, I am attaching the project I made today for checking purpose (the image has been deleted).
Posted: 28 Sep 2022, 10:01
by Hironori Takagi
Xavier wrote: 28 Sep 2022, 08:44
Good catch!
For example, there are the following reasons.
Layout: TVPaint
Layout check: PrintOut
Key-animation: Other software
In the above case, if the DPI cannot be embedded when exporting the continuous shot image, it is necessary to embed the DPI again with another application before printing, which is currently a problem in our studio.
The above is why sequence images need to maintain DPI.
Posted: 29 Sep 2022, 13:20
by Xavier
Currently working on this. Could you please try adding a "ignoreduplicateimages" "on" ?
Posted: 29 Sep 2022, 13:21
by Xavier
Hironori Takagi wrote: 28 Sep 2022, 10:01
Good catch!
Layout: TVPaint
This should be okay in the next build.
Posted: 29 Sep 2022, 14:09
by Xavier
Xavier wrote: 29 Sep 2022, 13:20
Sorry, don't bother, there's a parameter swap in the code. It should be fixed in the next build too !
Posted: 03 Oct 2022, 05:45
by Hironori Takagi
Xavier wrote: 29 Sep 2022, 14:09
i will wait for the update.
I received an inquiry from a Japanese user, so please take care of it.
Posted: 06 Oct 2022, 15:43
by Thierry
Hello Takagi-san,
We have released a hotfix today (https://forum.tvpaint.com/viewtopic.php ... 25#p130925) addressing these two issues:
  • (2) The hotkey "select mode" only displays "next mode" in the Japanese menu.
  • This rule will create wasted frames in TVpaint 11.7.0 when using George "tv_ClipSaveStructure" command (export heads of the instance).
The following issues will be addressed either at the end of this month or in the beginning of November:
  • (4) DPI is not reflected in export using George such as tv_savedisplay, tv_clipsavestructure.
  • Regarding "reading the DPI set when the image is imported", which we requested to Antoine in advance, it is also essential for us.
