Page 1 of 2
about moving selected pixels
Posted: 19 Apr 2013, 10:20
by Lukas
It would be nice when you use the lasso to select a part of the drawing, when you start moving the selection around, it would 'crop' the selection to only non-transparant pixels. And wouldn't add new pixels to the selection.
Photoshop behaves like this, it makes moving selections much easier.
Re: about moving selected pixels
Posted: 19 Apr 2013, 13:04
by Fabrice
Sorry, but I don't understand, would you mind posting an image to show us ?
Posted: 19 Apr 2013, 13:10
by Svengali
Perhaps a case of "Display" being checked during cutbrush operation - so all layers (and background) is being captured?
Posted: 19 Apr 2013, 16:13
by Lukas
Fabrice wrote:Sorry, but I don't understand, would you mind posting an image to show us ?
I'll try and make a recording of the different kind of behaviours and post it here
But...I need to find some time
Posted: 19 Apr 2013, 16:24
by Lukas
Lukas wrote:But...I need to find some time
Ehm, ok I just did it right away, no need to search for time...
Here's a video showing TVPaint selection + moving behaviour and then showing how the same actions in Photoshop have different results:
[qt]640,480,
http://www.lukaskrepel.nl/temp/TVP/Selection.mov[/qt]
I personally think the Photoshop way is better, but I understand Adobe has a crazy big team and money...
Posted: 19 Apr 2013, 19:43
by Sewie
That doesn't happen here. Here it crops like you see in photoshop.
(I'm on W7 64x.)
Looks like a bug.
Posted: 19 Apr 2013, 21:07
by Fabrice
strange indeed. we will check monday.
Posted: 22 Apr 2013, 06:46
by Lukas
Ah, that's strange.
It's like this for me on both 32 and 64 bit on OS X.
Another question about the lasso tool, is it possible to substract from a selection with the lasso tool? (Again, referring to Photoshop where 'shift' is Add to selection and 'alt' is Substract from selection)
Posted: 22 Apr 2013, 08:42
by Sewie
For me 'add' is on by default and subtract is by pressing the right mouse button, also by default. I have one of the buttons on the wacom pen set to erase and this works as 'subtract selection' as well.
Posted: 22 Apr 2013, 08:44
by Mads Juul
When using the Panning tool to move around my computer behaves the same way as Lukas.
I gueass Lukas is referring to the panning tool and not the transform tool.
-Mads
Posted: 22 Apr 2013, 08:56
by Svengali
Bug or not, why not use a cutbrush to accomplish the same thing?
Posted: 22 Apr 2013, 11:57
by Lukas
Svengali wrote:Bug or not, why not use a cutbrush to accomplish the same thing?
That's what I do now. But since these tools are nice too.
madsjuul wrote:When using the Panning tool to move around my computer behaves the same way as Lukas.
-Mads
Ah, I just checked the difference between 'Shape Transform: Pan' and 'Shape Transform: Position'.
'Shape Transform: Position' works a bit better. But it still doesn't crop transparent pixels when you lasso a selection. But there might be a way to add this to a custom tool if there's a function to crop a selection to opaque pixels or something.
Personally, I like the way 'Shape Transform: Pan' doesn't require me to hit 'enter' and doesn't show the transform box. But I guess that's also why it's adding stuff to the selection...
Posted: 23 Apr 2013, 01:13
by djsolomon
hi All I would like to add to this thread as a note to the TVP crew that there is an issue with the shape transform tool
I have it assigned to a key command and it crashes quite allot.
To the lovers of the cut brush I am right there with you it's an amazing tool BUT some times its not the best way to do something
and i think the beauty of TVP is the range of solutions it offers users... so it seems to me that no tools should crash the program...
here is what happens:
1 . I want to move a part of a drawing ( not the entire drawing)
2 I select the portion of the drawing using the shape select :freehand which i have assgned to a key command
3 I hit my key command for shape transform:position ( a bounding box appears around the selection AND the mask button becomes highlighted)
If i do not deselect( using my key command for Shape select clear ) immediatly after moving or aletering the bounding box - and i pick another tool the program crashes
fixing this would be great... me thinks ; )
my best , debra
Posted: 23 Apr 2013, 08:34
my best , debra
Hmm, indeed, that's a strange behavior.
Does anyone experiment the same thing ?
Posted: 23 Apr 2013, 13:01
by djsolomon
thanks for responding to the post Elodie...
I have been having this problem for some time - i think I posted about it a year ago.
. I am not sure if the issue is the mask or shape transform tool . I like being able ot move a selection with out having to make a cut brush- (when using the cutbrush you have to earase the original line work so this is faster...)
many thanks, debra
