Button: show/hide other layers with layer attenuation
Posted: 24 Jun 2014, 12:33
by Lukas
This came out of this conversation, I created it because TVPaint keeps resetting Layer Attenuation to 0% when you create a new project: http://forum.tvpaint.com/viewtopic.php?f=21&t=7366" onclick="window.open(this.href);return false;
- Click the button to hide/show other layers (with layer attenuation value, which percentage value it will remember forever, also across projects and reboots).
- Shift click the button to change layer attenuation percentage.
(You could shortcut it with and without shift, for example "H" and "Shift H" too)
Re: Button: show/hide other layers with layer attenuation
Posted: 24 Jun 2014, 12:56
Thank you for sharing this panel.
By the way, your request about remembering Layer Attenuation's value is to do listed since you asked for it.
Posted: 24 Jun 2014, 14:08
by Lukas
Cool, I guess this button will be obsolete!
Posted: 24 Jun 2014, 14:26
I don't think so : I was talking about the current fact where TVPaint reset Layer Attenuation's value each time you create a new project => this part is about to be fixed, as Layer Attenuation's value should be remembered.
Your button hides / shows layers with Layer Attenuation on, so I assume it will be still useful (you do not always want to enable Layer Attenuation).
Posted: 27 Jun 2014, 08:54
by Animark
Thanks a lot, Lukas. This button is very very useful!
