Storyboard action notes question
Posted: 06 Apr 2015, 17:07
Hi All, I'm "publishing" a storyboard to a pdf, and I'm wondering if there is a way to place action notes for subsequent bookmarked portions of a shot with their respective storyboard panels, rather than having them all listed under the first panel of a particular shot.
This is tricky to explain, but I'll try to go into more detail, in case the above isn't clear. When you're publishing a storyboard, if you want more than one storyboard panel for a particular shot, you add bookmarks at the points where you want more storyboard panels. When writing in the action box, there is only the one action box per shot, so all notes for each storyboard panel within a shot appear under the first storyboard panel of any particular shot. This makes for a bit of a clumsy, jumbled read.
Is there any way to have notes for each panel within a shot appear under their proper, respective storyboard panels?
I'm using TVP 10.5.4 64 Bits.
