Make those tool tips go away!! [Solved]
Posted: 09 Mar 2016, 00:23
by David_Fine
So I know there is a simple solution to this, but can I find it? NO!! I am getting those large tool tips which pop up whenever the pointer is held over something. It's annoying and I want to turn it off, but I can't find anything in prefs to do this. Where is it? Why can't I find it? Is it me?? Help!!!
Re: Make those tool tips go away!!
Posted: 09 Mar 2016, 01:17
by JQuinn
Oh my god I know the answer!!! My first bit of advice! Go to Top Menu>Help>Tooltips> choose none. Woo hoo!!! I must be a professional now! :o
Posted: 09 Mar 2016, 02:29
by ten_zero
Mr. Fine,
  •  Have you got the information in OS X Menu bar "Help" menu ?
    Perhaps your TVP.app requied to change "None".
Posted: 09 Mar 2016, 08:38
JQuinn wrote:Oh my god I know the answer!!! My first bit of advice! Go to Top Menu>Help>Tooltips> choose none. Woo hoo!!! I must be a professional now! :o
I told you it would arrive sooner than expected :D
Re: Make those tool tips go away!! [Solved]
Posted: 09 Mar 2016, 18:50
by David_Fine
Joanna, you did it!! Thank you. I knew it would be painfully obvious once I was told, but having said that, I wonder why that setting is in the Help menu instead of Preferences under the interface tab? I searched for "tool tip" in the manual but nothing turned up because you need to search for "tooltip". Doh!
Posted: 10 Mar 2016, 02:27
by ten_zero
David_Fine wrote: I knew it would be painfully obvious once I was told, but having said that, I wonder why that setting is in the Help menu instead of Preferences under the interface tab? I searched for "tool tip" in the manual but nothing turned up because you need to search for "tooltip". Doh!
 Because "tool tip" is not common words in French and Japanese ; in case of "langage barrier" why Comtuper Software localize be carefuly.
If TVPaint English mode "tool tip" culturized "Balloon / pop-up help", you might seek "Help" command list in menu bar at first.
