drawing recorder
Posted: 26 May 2016, 11:53
If you want to use the drawing recorder to animate up a drawing how do you to it best?
When you copydrawing an image like inmy case you often not draw so fast as you want the priewe later should be so the get far too many frames. I tried to solve it partly by starting a project with 10 fr/ sec but I am not sure if that was the best way. It´s still way too many frames.
Or can I go into the timeline and somehow delete every second frame easily?
Great thanks!
/ Mattias
Great thanks!
/ Mattias
